misfires after disconnecting the battery
2007 TOYOTA PICKUP
4 CYL
MB-POWER
  • 80 POSTS
Any Toyota 2006 and up models, if we disconnect battery for any reason and reconnected again most of times (not all times) it will run with misfiring (engine will not run normal) and the rpm's will go down. some times (specially with automatic transmission) engine will shut off when you put it in D or R.
to resolve this problem we should disconnect battery or ECU and reconnect it again for several times ( some times two to three times and some times up to seven or eight times! it is by luck ) then engine will comeback to normal firing .
I do not know why this problem with Toyota only and why some times only ?
even Toyota dealer informed me : it is normal and do not disconnect battery during maintenance.
Any advice ?
Thanks
Sep 17, 2017 at 9:38 PM
STEVE W.
  • 15,345 POSTS
That is common on many newer vehicles. It is because the engine computer starts at a baseline that assumes new sensors and no wear. As it ages and sensors and parts wear the computer learns the "new" normal and keeps things running smooth.
When you disconnect the battery all of that information is erased and the computer needs to re-learn everything all over, from idle control to compensation for wear.
Basically you try real hard to keep battery voltage intact. Either do not disconnect the battery unless it is very necessary or be prepared to have the system relearn the controls. As for the reconnect multiple times, that is a waste of time as once the data is erased from the memory the only recourse is for it to relearn.
I use a jump box connected to the vehicle to change out batteries just to keep from clearing the memory.
Sep 18, 2017 at 2:48 AM
MB-POWER
  • 80 POSTS
Thanks for advice , but I am facing this situation with Toyota vehicles only!
Sep 18, 2017 at 4:25 PM
STEVE W.
  • 15,345 POSTS
Does not change the fact that it is common on many makes for the ECM to clear the learned memory when the battery is disconnected. I see it on many vehicles from Audi, BMW, VW, Chrysler, Ford, GM, Toyota, Mercedes, Honda, Lexus. It depends entirely on how they store the learned data. On some they have a small back-up battery or a large capacitor that can hold the memory for an hour or so. On others it clears almost instantly. Then the PCM loads default values that may or may not allow the engine to idle or even run depending on how it has been maintained and how worn it is.
As an example take a dirty throttle body. The plate can no longer close properly because of carbon build up. The PCM learned how to keep it idling correctly by adding more air through the IACV or by holding the plate farther open to maintain the correct speed. Now you disconnect the battery. The PCM is wiped and loads the default idle setting. That setting however no longer functions because of the build up inside the throttle bore or IACV. So the engine will not idle, it might buck and misfire or stall because it is not getting proper fuel.
On some vehicles you use a scan tool to trigger a re-learn, just the same as triggering a KAM reset if you replaced a cam or crank sensor.
On others you perform the reset by just driving the vehicle around.
Sep 18, 2017 at 7:27 PM
MB-POWER
  • 80 POSTS
thank you very much.
Sep 18, 2017 at 10:09 PM
STEVE W.
  • 15,345 POSTS
You are welcome. I can also tell you it will get worse as the companies add more and more electronics to even the low end vehicles. They cry because they need to remove weight from the cars to get better mileage, then turn around and add four new modules and one hundred pounds of wire to make the turn signals work. Or the stupid idea to put the fuse panels in the rear of the vehicle then running wires from the front mounted battery back to it so it can power the headlights!
Plus auto makers are really trying to push DIYers and even independents from being able to repair the vehicles at all.
Sep 19, 2017 at 4:47 AM
