I have a stripped bolt it was broken.
I drilled out the stud and tapped it.
I used a 5/16-18 helicoil and new bolt.
Helicoil failed. I did not re-drilled but used a 3/8 tap and cut new threads.
Replaced bolt with a 3/8-16 thread. And it too is failing.problem being it will not pull the manifold tight enough to stop the leak. Should I have used a metric bolt? Something a little bigger?
Please any advise I do not want to pull this head again if there is an alternative. Thanks. JC
Jan 14, 2019 at 4:04 PM
