Alternator not kicking out voltage to battery
100,000 MILES • 2WD • AUTOMATIC
QUANTAE
I have a new battery, and new alternator, but the battery keeps draining. I was told that the alternator is not kicking out any voltage to the battery. also, windows do not roll up or down. i am thinking I have some electrical problems some where but do not know were to start.
Dec 30, 2017 at 10:20 PM
Good morning.
Can you check the voltage at the battery with the engine running?
Dec 30, 2017 at 10:35 PM
QUANTAE
Yes I can, but when I am getting it checked they say the battery not charging. battery will drain after two or three days.
Dec 31, 2017 at 12:34 AM
Okay, can you tell me the voltage reading at the battery engine running after you charge it? Look for 14 to 14.5 volts. If you do not, check the heavy wire at the back of the alternator for battery voltage.
Dec 31, 2017 at 12:37 AM
QUANTAE
When I check the voltage at the battery it has no voltage, but when I check it at the alternator it does have voltage.
Dec 31, 2017 at 12:42 AM
what voltage? can you give me the readings?
Dec 31, 2017 at 12:47 AM
