Serpentine Belt Replacement?
SREEVES88
  • 2006 KIA SPECTRA
  • 2.0L
  • 4 CYL
  • FWD
  • 97,000 MILES
My vehicle doesn't seem to have a belt routing diagram and they need to be replaced. What is the best way to do this? I believe I have located the tensioner pully but am not completely sure.
Tuesday, September 2nd, 2014 AT 3:26 PM
  • 110,012 POSTS
Let me know if this helps.
https://www.2carpros.com/diagrams/kia/spectra/2006
and
https://www.2carpros.com/articles/replace-serpentine-belt
Tuesday, September 2nd, 2014 AT 7:19 PM
NATGONZ09
  • 2006 KIA SPECTRA
Air Conditioning problem
2006 Kia Spectra Front Wheel Drive Automatic
Yes, my question is that I am in the process of changing the belts on my car and I am stuck on how to finish. I already took out the ac belt but I am having difficulty putting the new one back on. So my question is what is the process of placing the new belt back on? Thanks and any answer would be helpful.
Tuesday, July 21st, 2020 AT 2:04 PM (Merged)
DOCFIXIT
  • 18,828 POSTS
Loosen bolt in center of tensioner pully back off adjusting bolt position belt tighten adj. Bolt till belt deflecys 1/2 " tighten pully bolt
N CHRISTIAN SMITH
  • 2006 KIA SPECTRA
  • 2.0L
  • 4 CYL
  • MANUAL
  • 200,000 MILES
I replaced the timing belt and had to take off the air conditioner power steering and alternator belts and now do not know which way those three belts go back on. Do you have a routing diagram or something I can see to put the belts back on?
Tuesday, July 21st, 2020 AT 2:05 PM (Merged)
WRENCHTECH
  • 20,761 POSTS
If it has three separate belts, then there are no diagrams available. The alignment will be very obvious. You have three separate pulley track and a simple visual will tell you which pulleys align with each other. The belts are layered.
SHEFFIELD734
  • 2005 KIA SPECTRA
  • 4 CYL
How do you change the air conditioner belt on a 2005 Kia Spectra?
KEN L
  • MASTER CERTIFIED MECHANIC
  • 49,075 POSTS
Yes there is a tensioner that will need to be released. Here is a guide that will let you know what you are in for when changing the belt.
Let me know how to goes, we are here to help.
AIRFORCEFREAK10
  • 2004 KIA SPECTRA
  • 97,000 MILES
I live in Washington State so it's very cold outside right now. I park my car outside so this may be a factor. When I start up my car, everything is fine. I can let my car warm up or I can just drive it away. When I start driving it though, I hear this loud screeching noise coming under my hood. I went to my mechanic and he said that they are my belts. So he tighten power steering, water pump and alternator belt. Also he changed my power steering fluid too. My car doesn't make this sound all the time, but it has done it three times when I was driving to work in the past ten minutes. It's very bad because I can hear the screeching noise and so can other people. Are my belts going bad, power steering going out, my pulleys or belt tensioner that need to be changed or is my problem all the above? I also had this problem during the summer time, so this is just not happening; but I'm finding out that the problem is more common when it's cold outside.
Any help would be appreciated and thanks for the help!
Tuesday, July 21st, 2020 AT 2:06 PM (Merged)
  • 52,797 POSTS
I would have the belts replaced with good quality belts. They are worn out. Once they squeel, they are stretched and will break if they are tightened.
AIRFORCEFREAK10
Thank you for the advice, I'll tell my mechanic that I want the repair done. I'll keep you updated if I hear improvements when the belt gets changed. Thank you again for your help!
  • 52,797 POSTS
Good luck
roy
WYONATW
  • 2003 KIA SPECTRA
Other Category problem
2003 Kia Spectra 6 cyl Wheel Drive Type unknown Automatic 100000 miles
Trying to change alternator and a belt. Unable to
shift gear to neutral to take off belt.
DAVE H
  • 13,384 POSTS
REMOVAL
Remove negative battery cable.
Open B terminal cover cap.
Remove B terminal nut.
Remove B terminal lead.
Disconnect generator L and S terminal connectors.
Loosen pivot bolt and tensioner mounting bolt. Do not remove.
Relieve tension on drive belt by rotating adjustment bolt.
Remove drive belt from generator pulley.
Remove tensioner mounting bolt and belt tensioner.
Remove generator pivot bolt.
Loosen bolt at base of adjusting bracket and rotate the bracket up.
Lift generator from engine compartment.
JEREMIAH_P
  • 2003 KIA SPECTRA
2003 Kia Spectra
How do I change it?
  • 110,012 POSTS
Take a look at this page. It shows the alt and adjuster. NOTE: You must first loosten the bolts on the bracket so it can move.
https://www.2carpros.com/car_repair_information/year/2003/make/kia/model/spectra/2003_kia_spectra_drive_belt_routing_diagram.htm
JOSEPH GEE SR.
  • 6 POSTS
  • 2003 KIA SPECTRA
  • 1.8L
  • 4 CYL
  • FWD
  • 120,590 MILES
Having problems getting the front belt off so I can change the Alternator belt need to know how to get it off.
SATURNTECH9
  • 30,869 POSTS
Loosen the alternator mounting bolts and then loosen the belt adjusting bolt.
JOSEPH GEE SR.
  • 6 POSTS
But I have already loosened all of that and I still cannot get the front belt to come off. So want do I do with it now?
SATURNTECH9
  • 30,869 POSTS
Take some pictures of the belt area and post them so I can see what is going on.
JOSEPH GEE SR.
  • 6 POSTS
Okay, when I get back to the car in the morning I will take some pictures off it and send them to you.
