fuel pump
ALL OTHER MAKES ALL OTHER MODELS
TEACSCO
how can u tell if the fuel pump is bad
Mar 25, 2006 at 8:34 AM
PEPPERMRJ
  • 1,158 POSTS
Welcome to the forum. :)
First thing to try is to listen for it running. When the key is turned to the on position you should hear the buzz for a second or two. If you don't hear it in the drivers seat recruit a helper and try listening at the filler pipe with the gas cap off.
N0 hum = no pumping. Check the fuses and the relay before condeming the pump as a failure.
Good luck and let us know.
Mar 25, 2006 at 11:08 AM
