96 intrepid transmission
1996 ALL OTHER MAKES ALL OTHER MODELS
XBAG
have you ever heard of a transmission locking up the front wheels while going down the road? if so what could be a possible cause? took it to a tranny shop and they say it's the transmission, and wanted $1300 or so to fix. i can get a salvage tranny for $500 and replace it myself , but that is a lot of work if the tranny is not the problem! help please!!!!
Jan 12, 2006 at 4:13 PM
BTKHUME
  • 5 POSTS
it could be your trasmission if a shop told you that it is more likely to be that but it could even be front bearings or your cv axle
Jan 16, 2006 at 11:09 AM
PALOMA PAUL
  • 14 POSTS
Check the front axles. Pop them out of the tranny with a pry bar, while the wheels are raised off the ground see if the wheels turn. If they turn it's the tranny. If one or both don't you have a bad front axle.
As for replacing a front wheel drive tranny, you do realize the engine and transmission come out as one unit then you seperate them. If it is your tranny leave it to the pros. A salvage yard tranny will have no warranty and will require alot of time and frustration on your part.$1300 is about right for a tranny job. Make sure the warranty is in writing.
Jan 16, 2006 at 12:37 PM
