1994 Toyota 4Runner Spun Bearing
You need to investigate why those bearings when bye-bye. might be a bent crank,taper or out of round. Best fix is to get a crank kit.
Suggested Repair
Measure rod-bearing clearance with Plastigage and use the correct undersize bearings if needed. Inspect the crankshaft for bend, taper, or out-of-round wear, and use a crankshaft kit if it is damaged. Keep the engine extremely clean during assembly and determine why the bearings failed.
Conversation Summary
The owner of a 1994 Toyota 4Runner 3.0 spun a rod bearing and asked whether the bearings could be replaced without removing the engine, how to check for crank damage, and whether remaining soft bearing material meant the crank was still protected. The owner had already installed the wrong-size bearings. The expert advised using Plastigage to measure clearance, inspecting for a bent, tapered, or out-of-round crank, and using a crank kit as the proper repair while keeping the assembly clean.
