2004 Toyota Tundra Check Engine Light
2004 ALL OTHER MAKES ALL OTHER MODELS
VIC MCCOWN
At 42,000 miles engine check light has come on. The pickup runs like it always has. Checked everything out looks great. Is this just programed to come on at that mileage. How do I make it go off?
Oct 10, 2006 at 6:21 AM
  • 75,988 POSTS
A scan tool can read and clear the code that turn on the check engine lite.
Oct 12, 2006 at 10:02 PM
BACKYARDMECHANIC
  • 337 POSTS
Hi Vic,
I have a 2002 tundra and also had the check engine light come on. After using a scan tool it was determined that the #1 o2 senor in bank # 2(passenage side before the cat) was defective. I replaced the senor and cleared the code and everything is fine now. However I later found out ( after buying and replacing the senor) that there was a recall on the o2 senor. I don't know if the '04s were also included in the recall but maybe it's worth contacting the dealer.
Nov 6, 2006 at 10:29 AM
Suggested Repair
Use a scan tool to read the stored trouble code before clearing the check engine light; it is not mileage-programmed. If the code indicates a faulty oxygen sensor, such as bank 2 sensor 1, replace it and clear the code. Also ask a Toyota dealer whether the 2004 Tundra is covered by an oxygen-sensor recall.
Conversation Summary
The owner of a 2004 Tundra says the check engine light came on at 42,000 miles while the truck continued to run normally, and asks whether the light is programmed to appear at that mileage. Experts advise using a scan tool to read and clear the code. One owner of a similar Tundra found a defective bank 2 oxygen sensor and later learned of a related recall, so contacting the dealer is suggested.
