2001 Grand Caravan
2001 ALL OTHER MAKES ALL OTHER MODELS
EDWARD GIAFONE
My 2001 Grand Caravan 6 clylider has 74,652 miles. I have two problems. The first is the driver side window doesn't work. I checked the fuses and they are all good. All the other levers on the door work properly I have no problem with the passenger window or the locks. Also I don't get any heat out of the passenger side vents, only cold air. Any suggestions will be appreciated.
Feb 26, 2007 at 2:01 PM
BHUGG
  • 157 POSTS
Are there any noises when the switch is pressed? There should be a slight click when the swicth is pressed. If there is no sound when you press the swicth, and the other windows work, then the switch is probably bad.
I'm not familar with the Caravan's heater. If it is getting heat out of the drivers side, and you have individual climate control for each side, then is sounds like there might be a vacuum leak or stuck damper under the dash.
Good luck
We are happy to help with our advice.
Let us know what you find out.
If we help you, let us know. Give us a vote.
Feb 27, 2007 at 2:12 AM
