2001 Daewoo Nubira clutch/transmission problem ?
2001 ALL OTHER MAKES ALL OTHER MODELS
HIDEOUS
MY Nubira recently started slipping a bit.
I have the manual 5 speed and it goes in and out of gear just fine.
However, if i step on the accelerator more then slightly it starts to slip for a few seconds then catches and goes unless i push even harder in which case it slips out then goes again etc.
Id does this in every forward gear but not reverse.
I think but am not positive that it is a problem with the pressure plate on the clutch what do you think ?
Also does my maek and model have a clutch that can be adjusted ?
And lastly what can i expect to fix this problem ?
Dec 16, 2006 at 10:47 AM
CARUNDELL
  • 602 POSTS
[quote:11a1e30704="Hideous"]MY Nubira recently started slipping a bit.
And lastly what can i expect to fix this problem ?[/quote:11a1e30704]
Hey Hideous,
Sounds like a complete clutch job is in order, friction plate, pressure plate and throwout bearing. Its also recommended to get the flywheel resurfaced too!!
Chris
Dec 16, 2006 at 10:55 AM
HIDEOUS
if this problem started 2 days ago how long do you think it will last before it goes kaput ?
Dec 16, 2006 at 12:40 PM
DJFXDJFX
yep you need a clutch plate its fairly cheap the problem is labor since the transmission has to be opened.. the plate is basicly a brake pad that wears down just the same and when low stops funtioning properly
Dec 18, 2006 at 7:35 PM
