2000 S10 Pickup
2000 ALL OTHER MAKES ALL OTHER MODELS
JMIRABELLI
My pickup has been having problems starting. The repair shop has replaced the ignition control sensor, crank sensor (two times), starter. Today the pickup failed to start. This normally happen when the weather was below 30 degrees but today it was in the 40's. I am at a lost. I even replaced the battery to ensure I had larger crank voltage. What should I do next.
Apr 5, 2007 at 1:40 AM
JMIRABELLI
My pickup has failed me six times. The local repair shop has checked everything and replaced the ECM, Crank Sensor two times, starter, and even the battery to improve the crank voltage. This normally happen when the temp was around or below 30 degrees but today it was in the 40's. What is the next step???
Apr 5, 2007 at 1:46 AM
SERVICE WRITER
  • 9,123 POSTS
You need a shop more capable of troubleshooting. Does it turn over (crank) when the no start is happening or nothing at all?
May 2, 2007 at 12:38 PM
