1998 BMW 328i Electrical Problems
1998 ALL OTHER MAKES ALL OTHER MODELS
ASWAYZE76
At first it was my radio. The lights would not stay on. Now, my a/c-heater will not always come on. When a/c does work and I have it on top and feet, cold will come out of top and heat will come out at feet. Now when the air works, the radio won't work. Can someone tell what possible could be wrong?
Apr 1, 2006 at 1:58 AM
LOSONE
  • 1,616 POSTS
BMW's are famous for ground wire problems. Under the hood there is a clump of brown wires that attach to the body. Remove the bolt and clean the connection. Make sure all battery grounds are clean on the engine and the terminal is clean. Good luck
Apr 1, 2006 at 3:36 AM
Suggested Repair
Clean the under-hood body ground: remove the bolt on the clump of brown wires attached to the body and clean the connection. Also clean all battery grounds on the engine and the battery terminal.
Conversation Summary
The owner of a 1998 BMW 328i reports radio lights that will not stay on, climate control that does not always come on, mixed cold and hot air from different vents, and the radio failing when the air system works. The expert says BMWs commonly have ground problems and recommends cleaning the brown body ground wires under the hood plus all battery and engine grounds.
