1995 Chevy Silverado Electrical Issues
NOS155
  • 16 POSTS
hi, i have a electrical problem that is causeing many problems to do with the wipers, 4WD, heater blower, and gear indicator light. none of these things work when i try to use them. when i turn the ignition switch backwards to just play the radio i turned the wiper control switch and i hear a buzzing noise coming from the wiper motor also all the tach lights show up very dimm. i disconected the wiper motor and tryed to see if all the funtions worked again but no luck. i started noticing problems one day when the gear indicator light began flickering one day and eventually stayed on as the vehical warmed up and now it only appears when i turn the igniton switch halfway then disappears once the truck is fully started, and now nothing works.
any help would be greatly appreciated!
thanks.
Dec 11, 2006 at 6:09 PM
CARUNDELL
  • 602 POSTS
[quote:4f7683d153="nos155"]hi, i have a electrical problem that is causeing many problems to do with the wipers, 4WD, heater blower, and gear indicator light. none of these things work when i try to use them. when i turn the ignition switch backwards to just play the radio i turned the wiper control switch and i hear a buzzing noise coming from the wiper motor also all the tach lights show up very dimm. i disconected the wiper motor and tryed to see if all the funtions worked again but no luck. i started noticing problems one day when the gear indicator light began flickering one day and eventually stayed on as the vehical warmed up and now it only appears when i turn the igniton switch halfway then disappears once the truck is fully started, and now nothing works.
thanks.[/quote:4f7683d153]
Hey nos,
Sounds like a possible ignition switch problem. If you have a meter, you can test for proper voltages
@ the ign switch connector under dash.
Chris
Dec 12, 2006 at 6:16 AM
Suggested Repair
Suspect a faulty ignition switch. Use a meter to check for proper voltages at the ignition switch connector under the dash.
Conversation Summary
The owner of a 1995 Chevrolet Silverado reported that the wipers, 4WD, heater blower, and gear indicator light stopped working. Turning the ignition back to accessory and operating the wipers caused a buzz from the wiper motor and dim instrument lights; disconnecting the wiper motor did not restore the other functions. The gear indicator had flickered, stayed on as the truck warmed, and later appeared only with the key halfway before disappearing when fully started. The expert suggested a possible ignition switch problem and recommended testing voltages at the ignition switch connector under the dash.
