1995 BARRETA
1995 ALL OTHER MAKES ALL OTHER MODELS
OZARKMAN1958
CAR SEEMS TO RUN FINE BUT SMOKES BAD. AFTER ITS DRIVEN FOR A WHILE IT SOMETIMES CLEARS UP, AFTER IT SITS AND STARTED AGAIN IT SMOKES BAD AGAIN. THE LIFTERS ARE VERY LOUD ALSO. I WAS TOLD THE LIFTERS WERE BAD, MAYBE YOU CAN HELP ME OUT. OH YA ITS A 3.1 V6 ....THANK YOU
May 2, 2007 at 3:38 AM
SCORPIO1025
  • 16 POSTS
if the lifters knock bad then yeah they prollly are bad. only tip i can give u is that if ur going to go through the trouble to replace them... replace all of them... not just the ones that are bad. if ur just fixing to sell... then its ur choice really
what color is the smoke? if its black u prolly have a fuel problem... ie, need new fuel filter, need injecters cleaned, prolly need whole fuel system cleaned (which requires a trip to the shop). If its white or blueish, ur prollly burning oil and that could be from a number of things including blown headgasket. if ur going ot replace the lifters ur going to end up replacing the gaskets too so that might fix ur prob. if it smells sweet its an antifreeze leak.
keep checking on all the levels for all the fluids while ur working on this... last thing u prolly need is the engine to freeze from no oil, or over heat from no antifreeze. also check ground to see if any fluids are leaking onto ground... kinda gives u a rough idea on where they are leaking
May 15, 2007 at 4:26 PM
BLUSTEEL1
Also, while your replacing the lifters, go ahead and replace the valve seals. Oil may be leaking past these into the cylinders causing blue smoke at start-up.
Oct 21, 2008 at 1:46 AM
