1994 TBird SC Won't run
1994 ALL OTHER MAKES ALL OTHER MODELS
RCHEADRA
Don't have any fuel pressure to the car, code say's its a bad fuel pump relay. Bought a new relay but cannont find the old one to replace it. Where is the relay placed, need to get the car home soon as it's in a parking lot!!! If this is difficult to change due to location, is there a way to bypass the relay to run the car home?
Jun 14, 2006 at 2:52 AM
TAURUSWHEEL
  • 718 POSTS
Is the relay located within the pcm unit?? You're not talking about the interia switch, are you?? does it have a little push button on top,, just looking for clarification.
Jun 14, 2006 at 12:30 PM
RCHEADRA
I was sold a relay for the fuel pump and can't find where it goes. I talked with Ford and they say it's part of the control unit mounted behind the right headlight. I'm going to check the fuel pump and then change the pump or control box and see if that corrects it.
Jun 15, 2006 at 10:16 AM
TAURUSWHEEL
  • 718 POSTS
I was looking thru my manuals, the only thing I could find for your car is that the pcm unit is mounted near the right headlamp.. maybe you have to take it off and replace the part internally..
Jun 15, 2006 at 12:36 PM
