1994 Geo Metro fuel problem
DKHALES65
  • 1994 ALL OTHER MAKES ALL OTHER MODELS
The timing belt broke on my Metro. After changing belt and adding new plugs the car won't start. The carb. Is not getting fuel, but all relays, fuel pump, and filter is working properly. Car will start when starer fluid is sprayed in engine. Any ideas?
Tuesday, April 17th, 2007 AT 8:02 AM
The most likely causes are:
1. A dead fuel pump (could be the pump, pump relay or wiring circuit);
2. A plugged fuel filter;
3. Low fuel pressure (weak pump or restricted line); or
4. No pulse signal to injectors (bad injector relay or PCM driver circuit).
Saturday, April 21st, 2007 AT 5:39 AM
