1987 Caviler Won't start Cold
JC REED
  • 1987 ALL OTHER MAKES ALL OTHER MODELS
I have a 1987 Caviler that refuses to start when it is cold. It has a 2.0 Litre 4-cyl with Automatic with 134,000 miles on it. When it starts by holding the throttle about 1/3 down and engaging the starter until it runs and doesn't die, it runs good with plenty of power. And when the weather is warm it starts O.K. I have replaced the fuel filter and it has new plugs and I changed transmission oil and filters and a new air filter and it has a new radiator and battery. I haven't changed the plug wires but the plugs are whitish when I pull them. The wires run behind the engine and down under the Throttle body. Could it be the wires or point module? Would a code reader be of help. Thanks for any advice for my work car.
Friday, February 2nd, 2007 AT 9:40 AM
The EFI system is not made to start with the foot on the pedal, just turn key and it'll fire up. Very obvious it has a problem.
Last Tune-up? Try the coolant temperature sensor it replaces the choke on a Carb.
Thursday, February 8th, 2007 AT 1:05 AM
