1984 Questions for all other cars 2 CYLINDER CUSHMAN
TLR240
  • 1984 ALL OTHER MAKES ALL OTHER MODELS
Engine Mechanical problem
1984 Questions for all other cars 4 cyl Two Wheel Drive Manual
HAVE A 2 CYLINDER MOTOR IN A CUSHMAN. WHEN U GIVE IT GAS IT CUTS OUT, BACKFIRES AND DIES. IT FEELS LIKE IT LOSES COMPRESSION OR POWER
Saturday, May 2nd, 2009 AT 12:30 AM
KHLOW2008
  • 41,814 POSTS
Hi TLR240,
There are many possibilities fot this to occur.
1. Carburettor. It could have a fault in the power or accelerating pump or jets. Could be due to low float level.
2. Ignition timing. If equipped with contact breaker, the adjustment could be out of specs.
3. Insufficient air going in. Check if the air filter is clogged.
4. Spark plugs and/or wires. Misfiring would cause the engine to hesitate or stall when giving it gas.
Tuesday, May 5th, 2009 AT 1:58 PM
