I want to test the thermostat to see if maybe it is sticking, but I have no idea where the thermostat on an 04 grand am is.
Please could someone help me with this one? If my husband found out I broke the car it would be horrible.
Confirm whether the engine is a 2.2L or 3.4L before testing the thermostat. On the 3.4L, it is at the end of the intake manifold beneath the housing connected to the upper radiator hose, and the crossover exhaust pipe must be removed for access. On an automatic 2.2L, remove the exhaust manifold and the thermostat housing-to-water-pump feed pipe to reach it. Also investigate possible internal coolant loss and the overheating rather than assuming the thermostat is the only cause.
The owner of a 2004 Grand Am reported an add-coolant warning, a coolant leak, and later overheating, and asked where the thermostat is located. The expert explained that unexplained coolant loss can be internal and that thermostat failure is associated with overheating. The expert then gave access locations for both the 3.4L and automatic 2.2L engines.
