01 T&C belt squeals sometimes at startup; compressor clu
2001 ALL OTHER MAKES ALL OTHER MODELS
BNSHOTROD55
Our 2001 Town and Country's belt has been squealing at startup periodically. It seems to be mostly at startup when the van is cold. I've also got it to quit by pushing the A/C button to off. Everything seems to work fine after the squeal stops. The squeal usually is 3 to 5 seconds, but it did do it once for 10 to 15 seconds.
Is the compressor going bad? Or does the system need oil? Do A/C clutches lock up?
The van has just turned 100,000 miles and the compressor was replaced at 65 or 70k by the dealer.
Thanks
Sep 19, 2006 at 10:20 AM
JPAM
  • 307 POSTS
i think the clutches do lock up time to time from what ive heard and/or read. but the compressor its self usally go.. as far as low on oil go.. the fluid itself keeps it lubed up...
Check your belt for ware, self tenstioner is working right... for now just start your van up without ac on and then turn it on after a few seconds go by....
jess s
Sep 20, 2006 at 11:35 PM
