2001 Dodge Dakota Blower Motor Quit
2001 ALL OTHER MAKES ALL OTHER MODELS
ROADDOG71201
01 dakota 2.5 60,000m my blower motor quit on me t checked fuses i have power at the motor itook the motor out and hooked 12 v direct it works if i ground it direct it will work (high only)everyone is telling me there is a relay on the ground but no one knows where help!
Sep 24, 2006 at 8:58 AM
JPAM
  • 307 POSTS
ok of course its only going to have high on a charger.
its more than likely its not your motor, but your speed swtich that is on the heater/ac panel.. they are pretty good for going out. though they normally have a few setting go out first before nothing
good luck jess s
Sep 25, 2006 at 4:23 PM
ROADDOG71201
it was the resister block located in the duct work next to blower motor thanks
Sep 30, 2006 at 1:24 PM
JPAM
  • 307 POSTS
thank you for getting back to us with what the problem was..
jess s
Sep 30, 2006 at 1:29 PM
Suggested Repair
Replace the blower motor resistor block located in the ductwork next to the blower motor. Direct power and a direct ground can make the motor run on high even when the resistor is failed.
Conversation Summary
A 2001 Dodge Dakota blower motor quit despite good fuses and power at the motor. It ran on high when grounded directly. An expert suspected the heater/AC speed switch, but the owner later confirmed the resistor block in the ductwork next to the blower motor was the failed part.
