All of a sudden no power
TINA WATSON
  • 2001 PONTIAC SUNFIRE
  • 2.2L
  • 4 CYL
  • 200,000 MILES
Hi, I hope someone can help. I parked my car for, and left for about an hour, came back and had no power to anything, no door, ping no lights on dash etc. I wiggled the shifter, and wiggled the key and suddenly everything powered up and the car started. Got it home, then same thing except, no power at all. So, I thought I would try and start it by touching the solenoid with a screw driver, with the ignition in on position, I walked away and it powered up! Went to start it and nothing again. I am feeling like it might be the ignition switch?
Monday, September 18th, 2017 AT 12:57 PM
JIS001
  • 3,411 POSTS
Have your battery tested. If ok make sure connections are clean and tight. Inspect battery cable at the fuse/relay box also and make sure that is clean and tight. If all is ok then yes it does sound like the ignition switch is faulty.
Monday, September 18th, 2017 AT 2:58 PM
TINA WATSON
Thanks JIS001 for answering, the battery cable was the issue. Whew!
Monday, September 18th, 2017 AT 5:57 PM
JIS001
  • 3,411 POSTS
Glad we could help out.
Monday, September 18th, 2017 AT 8:27 PM
