Air Vent flap makes noise when starting/stopping air conditioner
40,200 MILES • 3.5L • V6 • FWD • AUTOMATIC
BIPINBAXI
When I start my car and then when I turn on the air conditioner, the valve that may open or close to take the air in does not seem to work as required and makes noise (which sounds like tak, tak, tak) for about thirty seconds to a minute and then shuts down. Same thing when I turn off the air conditioner. Can you advise what is the problem and what needs to be done to fix it and approximate cost? Thanks.
Aug 3, 2016 at 7:49 AM
HMAC300
  • 48,601 POSTS
it may be a broken door in heat/air conditioner unit causing the actuator to sound like that. Or it may be a bad actuator you will have to check which one it is as there are a few one or two for temperature and direction of air.
Aug 3, 2016 at 8:25 AM
