Air conditioner fan stays running after key is removed
2002 CHEVROLET SILVERADO
180,000 MILES
RACCON
How to change the air conditioner switch? I do not know how to get to the switch. Could it be a problem with the ignition switch? Moving the air switch to 5 turned off the fan even when the ignition switch was off???
Aug 16, 2015 at 11:05 PM
RIVERMIKERAT
  • 6,110 POSTS
Which fan remains running? The engine cooling fan should remain running for a few minutes.
Aug 16, 2015 at 11:33 PM
RACCON
How do I get to the air conditioner switch on the dashboard? My truck does not have an electric fan for the radiator cooling
Aug 17, 2015 at 1:05 PM
RIVERMIKERAT
  • 6,110 POSTS
The fan switch appears to be an integral part of the AC control module behind the dash.
The panel it is mounted behind should have clips that secure it to the dashboard. Our reference doesn't go into the type of detail I need, so I'm going to go off what I remember from my dad's 2000 Silverado.
You'll need to carefully pop the handles off the controls. Then carefully pop the panel loose. Look around, they probably changed things in the 2 year interval. There might be between 2 and 6 Torx head screws holding the trim panel to the dash. After that, my reference shows the module as having two screws and four clips.
Aug 17, 2015 at 2:08 PM
RACCON
Thanks. I will go after it.
Aug 18, 2015 at 3:42 AM
RIVERMIKERAT
  • 6,110 POSTS
Good luck. Let me know how you fare.
Aug 18, 2015 at 4:12 AM
