Air conditioner blowing hot air?
176,000 MILES • 4.6L • 4WD • AUTOMATIC
BOBBY WILLIAMS4
When cutting on the switch for the A/C to work it blows out hot air.
Dec 4, 2022 at 5:26 AM
  • 110,248 POSTS
Is the A/C compressor engaging? If you turn the AC off, does the heat stop? Have you checked to see if there is enough refrigerant in the system?
Take a look through this link and let me know if it helps:
Also, let me know if you can control the temperature from hot to cool with the A/C off.
Dec 4, 2022 at 1:20 PM
