air conditioner light was blinking on and off and not getting very cold?
130,000 MILES • 3.6L • 6 CYL • 4WD • AUTOMATIC
SHERILYN FRANKLIN
  • 90 POSTS
My air conditioner light was blinking on and off and not getting very cold. I added freon and the gauge stayed in the red now my air conditioner light doesn't come on at all.
Jun 20, 2024 at 11:30 AM
TY ANDERSON
  • 719 POSTS
The air conditioner light flashing indicates there's a problem detected. It can be an electrical problem or low freon (usually). If the air conditioning system has a leak that means air has gotten into the system and adding Freon doesn't always correct the issue because the air in the system needs to be removed with an A/C machine. If you visually look at all the air condition parts under the hood to look for residue on the hoses, compressor, condenser and air condition ports. There shouldn't be any residue on these parts around seals or hoses.
If you do see residue then that is a clue for a leak and those parts will need to be replaced as the freon will leak out again after removing the air from the system and recharging. Recovering all the freon on the system will determine how much freon was in the system and give an idea that the system has a leak also.
From your description it doesn't sound like it's an electrical fault as it sounds like everything is working electronically
Let us know what you find or if we can give you more direction.
Jun 21, 2024 at 2:07 AM
SHERILYN FRANKLIN
  • 90 POSTS
Why did the gauge stay in the red??
Jun 21, 2024 at 2:48 AM
TY ANDERSON
  • 719 POSTS
Most likely it's because there is air in the system already taking up space and not the freon only. The system will pump air along with the freon, but you won't get cooling out of it.
Jun 21, 2024 at 3:20 AM
SHERILYN FRANKLIN
  • 90 POSTS
So, there is nothing electrical causing the ac light to not come on anymore?
Jun 21, 2024 at 3:46 AM
TY ANDERSON
  • 719 POSTS
There could be something electrical wrong like the switch stopped working however, from what you've described it doesn't seem to be that way. I'm leaning more towards the freon being low and not electrical.
Jun 21, 2024 at 6:29 AM
SHERILYN FRANKLIN
  • 90 POSTS
Is that why the gauge is in the red and how much freon goes in it, one of 2 cans??
Jun 21, 2024 at 6:47 AM
  • 55,711 POSTS
It sounds like you have too much refrigerant in the system, let's confirm by connecting a set of gauges then turn the system on to see what the readings are. Please go over this video to see what I am talking about:
https://youtu.be/4EqdrBVb0sY?si=A14_LKx7dF22txDh
Also, here is a guide that you can go over which should help as well:
Please go over these guides and get back to us.
Jun 23, 2024 at 3:38 AM
SHERILYN FRANKLIN
  • 90 POSTS
thank you
Jun 23, 2024 at 5:54 AM
