Air conditioner blowing out hot air
285,000 MILES • V6 • 2WD • AUTOMATIC
TSEIVERS59
We just replaced the ECM/anti-theft on our car and everything is working with the exception of the A/C cooling. It blows out very hot air like the heater is on. Can you help?
Jul 11, 2018 at 11:50 AM
Good morning.
The first thing I would do is to check and see if you have any Freon in the system. You need a set of gauges to see if it has enough pressure to allow the compressor to activate.
Do you have gauges to check this? If you do not, you can rent a set a parts store.
Jul 11, 2018 at 9:54 PM
TSEIVERS59
Freon is full, pressure is fine and lines are cold under the hood.
Jul 11, 2018 at 10:03 PM
Lines are cold? Does that mean the AC compressor is engaged and working?
Jul 11, 2018 at 10:17 PM
