A/C not blowing cold air and there is a mist coming from the vents
2011 HOLDEN COMMODORE
120,000 MILES • 3.0L • V6 • 2WD • AUTOMATIC
TREVOR RICHTER
When you put A/C on it does not get cold. Also seen a white mist come out of the vents.
Aug 19, 2021 at 9:23 PM
Sounds like we have a leak in the evaporator. However, we need to start with checking the pressures of the system. I suspect they are going to be low which means we have a leak somewhere. Then we need to pull it into a vacuum and add dye to the system and inspect the system for this dye. Here are some guides that will help with doing this:
https://www.2carpros.com/articles/re-charge-an-air-conditioner-system
https://www.2carpros.com/articles/air-conditioner-leak-detection
Once we know what the pressures are and confirm they are low then we can take the next steps as we may have a different issue but I think this is what is going to be needed.
Below is a chart that will help with correct pressures. Please run through this info and let us know what you find and we can go from there. Thanks
Aug 20, 2021 at 12:50 AM
