Do I need to buy an air compressor along with manifold gauges and a vacuum pump to service my truck's A/C system?
150,000 MILES
FERNIEA92
I remember the last time my car was serviced the tech was using an air compressor when using a vacuum pump. If I do need a compressor, how much hp should my new compressor have?
Thank you for your time.
Fernando Aguilar
Aug 7, 2023 at 12:06 AM
  • 110,251 POSTS
Oftentimes, the system is vacuumed down to check for leaks and then recharged. To do that, you do need a vacuum pump. I'm not sure what he did with a compressor.
Here is a link that shows that procedure:
https://www.2carpros.com/articles/re-charge-an-air-conditioner-system
Now, if you want to simply add Freon to the system, then no you don't need to vacuum the system.
Here is a link that explains how to do that process:
https://www.2carpros.com/articles/air-conditioner-how-to-add-freon
Let me know if that helps.
Aug 7, 2023 at 12:46 PM
FERNIEA92
Hi, thank you for your help and have an awesome day.
Aug 8, 2023 at 10:31 PM
  • 110,251 POSTS
You are very welcome and thanks for the update. If you have a chance, let me know if one of the recommendations takes care of the problem. I'm interested in knowing.
Also, if there is anything I can do to help, let me know.
Aug 9, 2023 at 2:21 PM
