my airbag light sometimes go off. my heat and windows work, but if the airbag light comes back on they stop. can you help?
Nov 13, 2019 at 7:31 AM
DANNY L
✓Experienced Mechanic
Hello, I'm Danny.
That means an SRS (supplemental restraint) code is stored in your vehicles computer.If you don't have access to a scanner/code reader most auto parts stores have a tool loaner program and can loan you one. AutoZone will check your codes for free.Here is a tutorial for you to read about how to check codes.
Having this code(s) stored might be directly related to the symptom you are talking about.After having the code(s) read get back to us with the code information and we can properly diagnose.Hope this helps and thanks for using 2CarPros.
