2002 Dodge Intrepid
JODIK1976
  • 2002 DODGE INTREPID
2002 Dodge Intrepid Two Wheel Drive Automatic
the airbag light is stuck on and the heater and blinkers wont work
Monday, February 15th, 2010 AT 8:04 PM
CARADIODOC
  • 34,364 POSTS
If all these things started at exactly the same time, you might suspect burned contacts in the ignition switch although I think the radio would be dead too. Overheated terminals in the switch connector are another possibility.
If these are separate problems, the most common cause of the air bag light turning on is a broken clock spring under the steering wheel. As it continues to break, the horn and cruise control will also stop working.
Caradiodoc
Tuesday, February 16th, 2010 AT 6:05 AM
