Engine is not getting fuel
166,000 MILES • 3.4L • 6 CYL • 2WD • AUTOMATIC
BELINDA MARCH
After hitting a pothole my engine quit running and will not start.
Nov 26, 2017 at 12:47 AM
  • 110,248 POSTS
You need to determine if it is indeed fuel related. If it is, check the fuel relay to see if there is power to it. If there is, you need to check for power to the pump. If there is power, the pump is bad.
Nov 27, 2017 at 6:54 AM
