1999 Acura TL P0401 EGR Code
STEPHANIE07301
Hi i have an 1999 acura 3.2 tl and i have recieved the code po401 and I know what it is I was just wondering if you have the repair procedure? and do you know if we would have to replace the whole egr system?
thanks so much!
Aug 24, 2007 at 6:32 AM
  • 75,988 POSTS
[quote:ebbf6ff069="stephanie07301"]Hi i have an 1999 acura 3.2 tl and i have recieved the code po401 and I know what it is I was just wondering if you have the repair procedure? and do you know if we would have to replace the whole egr system?
thanks so much![/quote:ebbf6ff069]
Open it up and check for carbons and make sure its getting vacuum from the vacuum switching valve/solenoid. No vacuum means it won't open up.
Aug 24, 2007 at 8:40 AM
LOSTINMARS
  • 222 POSTS
common honda v6 problem. the upper intake needs to be removed and the egr port drilled out. honda has an updated egr repair kit for these.
Aug 30, 2007 at 8:17 AM
Suggested Repair
Check the EGR valve for carbon buildup and confirm it receives vacuum from the vacuum switching valve/solenoid. On this Honda V6, remove the upper intake and clean or drill out the clogged EGR port; Honda offers an updated EGR repair kit. Replacing the entire EGR system is not the first step.
Conversation Summary
The owner of a 1999 Acura 3.2 TL has code P0401 and asks for the repair procedure and whether the whole EGR system must be replaced. Experts advise checking the EGR for carbon and vacuum from the switching valve/solenoid, and note this common Honda V6 issue is addressed by removing the upper intake and cleaning or drilling out the EGR port, with an updated Honda EGR repair kit available.
