Po401
1940 ACURA TL
STEPHANIE07301
Hi i have an 1999 acura 3.2 tl and i have recieved the code po401 and I know what it is I was just wondering if you have the repair procedure? and do you know if we would have to replace the whole egr system?
thanks so much!
Aug 24, 2007 at 6:32 AM
[quote:ebbf6ff069="stephanie07301"]Hi i have an 1999 acura 3.2 tl and i have recieved the code po401 and I know what it is I was just wondering if you have the repair procedure? and do you know if we would have to replace the whole egr system?
thanks so much![/quote:ebbf6ff069]
Open it up and check for carbons and make sure its getting vacuum from the vacuum switching valve/solenoid. No vacuum means it won't open up.
Aug 24, 2007 at 8:40 AM
LOSTINMARS
  • 222 POSTS
common honda v6 problem. the upper intake needs to be removed and the egr port drilled out. honda has an updated egr repair kit for these.
Aug 30, 2007 at 8:17 AM
