2003 Acura TL Dim headlight Control unit
10,100 MILES • 6 CYL • 2WD • AUTOMATIC
GEMANUEL
I paid for an answer to the question. How do I remove the dim headlight unit on passanger side?
Jul 7, 2010 at 3:22 AM
CARADIODOC
  • 34,413 POSTS
Hi gemanuel. Welcome to the forum. If the headlight is dim, it is obviously still working. This is typical of a bad ground, not a bad bulb. Proof is the high beam will also be dim, and the light will go out completely if you unplug the other headlight.
The most common place to find a bad ground is a corroded terminal in the bulb's connector, but the wire could also be corroded where it bolts to the body. If it's in the connector, just wiggling it will often get it working properly again, . . . for a little while.
caradiodoc
Jul 7, 2010 at 5:09 AM
CARADIODOC
  • 34,413 POSTS
I'll be out of town from Wednesday through Sunday night at the nation's second largest old car show swap meet at Iola, WI. Will check replies as soon as I get home.
caradiodoc
Jul 7, 2010 at 5:10 AM
