2000 Acura TL Air condition
BLKNMILD
  • 2000 ACURA TL
  • 6 CYL
  • FWD
  • 155,000 MILES
I turned on my A/C and I seen sparks and smoke coming from under the dashboard on the passenger side, so I turned it off. What could it be?
Wednesday, August 4th, 2010 AT 4:18 PM
KHLOW2008
  • 41,814 POSTS
Hi blknmild,
Something has shorted causing the sparks and smoke. You need to check the blower motor and its harnesses.
Thursday, August 5th, 2010 AT 8:59 AM
BLKNMILD
Yes I checked the motor and the harnesses, the motor is not even coming on.
Thursday, August 5th, 2010 AT 9:17 AM
KHLOW2008
  • 41,814 POSTS
Is there voltage at the blower motor?
Does applying direct battery voltage works?
Thursday, August 5th, 2010 AT 10:00 AM
