1. My car cranks sometimes and at other times it will not crank. I can drive it for miles on end, turn it off and it will not re-start. It can sit for over an hour and it may start then. When I turn the key, I hear a click. I have replaced the starter with an Acura starter in December 2007.
Could it be the Main Relay?
2. When do you suggest replacing the Timing Belt?
I just purchased this vehicle from my sister for my son who is away at college. I need to correct this problem.
3. Can you help me?
Wednesday, June 18th, 2008 AT 4:32 AM
