2006 Acura RSX Wheel nuts... continued.
20,000 MILES • 4 CYL • FWD • MANUAL
EDWARDSHARRIMAN
Yep, I'm doing it with the wheel on the ground.
I just broke my 1/2 socket drive.... must be pretty
stuck!
The penetrating oil hasn't made any difference. I let it soak for a couple hours.
How much heat might this need? I only have a MAP gas tourch... I doubt that'll heat it enough.
I'm pretty certain it is a left handed thread. I guess I can go to the dealer and buy the nut and see that way. There isn't much thread showing past the end of the nut.
Apr 2, 2008 at 2:22 PM
BLACKOP555
  • 10,386 POSTS
ill take what you posted and put it in the original topic we have, try to keep your replys there that way they dont get lost!
Apr 2, 2008 at 2:29 PM
BRUCE HUNT
  • 3,754 POSTS
They are right hand normal threads.
Apr 7, 2008 at 9:10 AM
BLACKOP555
  • 10,386 POSTS
bruce,
on another topic we figured out the problem.
the person that had work done on it previously had cemented the nut on, and he had to cut the shaft and replace.
just thought id let you know
Apr 7, 2008 at 11:45 AM
