2003 Acura RSX engine misfire
2003 ACURA RSX
85,000 MILES • 4 CYL • FWD • MANUAL
DERKE0324
  • 8 POSTS
recently my car had a bad knock sensor and o2 sensor i changed them then the check engine light went off then it came back on for misfire in all cylinders but the car has no sign of misfire while driving it but it does have a rough idle any suggestions what it could be mayb bad maf sensor
Nov 7, 2010 at 1:45 AM
KHLOW2008
  • 41,814 POSTS
Hi derke0324,
Misfiring could be due to spark plugs and related components or fuel pressure. Get them checked.
Nov 7, 2010 at 2:04 AM
DERKE0324
  • 8 POSTS
the car is running rich but i just changed the spark plugs and coil pack
Nov 7, 2010 at 2:07 AM
KHLOW2008
  • 41,814 POSTS
Running rich could be due to the following :
1. MAP sensor.
2. Throttle position sensor.
3. Fuel pressure.
4. Injectors.
5. Air filter
6. PCM.
Do you have any trouble codes?
Was anything done prior to this occurring apart from replacing the sensors mentioned?
Is the ignition timing correct?
Nov 7, 2010 at 2:20 AM
DERKE0324
  • 8 POSTS
Yea I got engine misfire codes cylinder 1 through 4
Nov 7, 2010 at 2:30 AM
KHLOW2008
  • 41,814 POSTS
If only misfire codes are present, you would need to check/test those components that can cause them.
A scan tool to monitor the data stream might be helpful.
Nov 7, 2010 at 2:38 AM
DERKE0324
  • 8 POSTS
So yu don't have any idea what it could be causing the misfire in all cylinders
Nov 7, 2010 at 2:42 AM
KHLOW2008
  • 41,814 POSTS
The possible causes have been listed out for you. You need to perform test to find out.
Nov 7, 2010 at 2:47 AM
DERKE0324
  • 8 POSTS
what test would be accurate
Nov 7, 2010 at 5:48 AM
KHLOW2008
  • 41,814 POSTS
A scan tool to monitor the datastream would be the most accurate.
Did you check the igniton timing?
What have you checked?
Nov 7, 2010 at 5:58 AM
DERKE0324
  • 8 POSTS
i didnt really check anything how do you check the ignition timing i mean the car drives fine no misfire whiling driving or anything just has a rough idle but says all 4 cylinders are misfiring
Nov 7, 2010 at 6:04 AM
KHLOW2008
  • 41,814 POSTS
The rough idle indicates the possibility of misfiring.
Ignition timing can be checked with a timing light.
Nov 7, 2010 at 6:07 AM
DERKE0324
  • 8 POSTS
would timing cause all 4 misfires
Nov 7, 2010 at 6:09 AM
KHLOW2008
  • 41,814 POSTS
Yes, if the ignition timing is out of specs, it can cause misfiring. Possible cause would be the cam timing that is out or the PCM needs to be updated or replaced.
Nov 7, 2010 at 10:25 PM
DERKE0324
  • 8 POSTS
If my car has low compression. Will it still be able to drive what are some symptoms of low compression
Nov 7, 2010 at 11:42 PM
KHLOW2008
  • 41,814 POSTS
When compression are low, longer cranking time would be required when starting.
Performance would be affected. Lack of power might not be too noticeable unless under loaded driving conditions.
Richer running condition due to reduced intake air volumn.
If vehicle can be started, you can drive without any problem.
Nov 7, 2010 at 11:54 PM
