2002 Acura RSX misfire
2002 ACURA RSX
10,712 MILES • 4 CYL • FWD • MANUAL
ACURARSX27
  • 5 POSTS
hi friends i have a acura rsx type s and the car misfire i change the feul pump and i change the spark plugs and i send the injectors to a shop for clean and evryting was good and the car still misfire so when i accelerate and the car reach 3500/4000 rpm the begin to misfire and when i give more gas it stil misfire 5000/6000 and more when i start the car in the morning the car idle bad the car sputer histation and i don't wat to do no body can help me whit this problem and i'am tired i think i gona blow this car up so friends can you guys help me give me a hint of aniting that can be the problem THANK YOU FRIENS A LOT HAVE A NICE DAY FURDER THANK YOU AGAIN.
Jun 25, 2008 at 2:15 PM
KHLOW2008
  • 41,814 POSTS
Hi acurarsx27,
I suspect it is the coil that is causing the problem.
Check if the coil connectors are bad. Check coil primary and secondary resistance, compare among the four.
Jun 26, 2008 at 4:03 AM
