Engine Cooling problem
1998 Acura NSX 6 cyl Two Wheel Drive Manual
Topped my oil and anti-freeze levels off. Drove 500 miles. Parked car for a wk. Started the car today, blowing white smoke out of the exhaust. Let the car idle and warm up for 5 mintues before I drove, then drove 2 minutes. White smoke still appears. 80*F outside and is still raining out. Car is garaged. any ideas? After the car cools off, I will check the fluid levels. Is it bad to drive the car if problem persists? thanks!
Aug 14, 2008 at 11:58 AM
