2003 Acura MDX Window won't close
2003 ACURA MDX
EMCENTYRE
2003 Acura MDX 55000 miles
The window behind the driver side is down and doesn't respond when the button is pushed to make it close. Is it possible it's just off track or needs a new fuse or a short in the wiring for the motor.
Mar 24, 2010 at 11:25 AM
KHLOW2008
  • 41,814 POSTS
Hi emcentyre,
Your previous post mentioned it going down by itself.
It could be a faulty master switch, door control switch or a faulty motor.
Check if you are able to pull the door glass up by hand. If yes, the egulator is bad.
Mar 24, 2010 at 11:45 PM
