1993 Acura Legend Temperature Gage (sp?)
1993 ACURA LEGEND
224,000 MILES • 6 CYL • FWD • AUTOMATIC
ALOBO16
when driving the gage goes from normal to high (red zone). I did have a mechanic look into this...he told me that I need a rebuilt engine because the coolant is mixing w/ the oil. A good friend of mine did check the oil..but the color of the oil look fine. What should I do?
Mar 25, 2008 at 3:12 AM
BRUCE HUNT
  • 3,754 POSTS
I doubt the coolant would mix with the oil. The oil has a higher pressure system than the coolant. What does the coolant look like? Why not have a leak down test done that is not that expensive to do and it will tell you what is wrong.
Mar 25, 2008 at 2:20 PM
