Hi sjkp,
Thank you for the donation.
After replacement of all the items, did you bleed the system?
Are you getting any coolant losses at the radiator?
BLEEDING COOLING SYSTEM
Always bleed air from cooling system when changing coolant. Open bleed bolt on coolant outlet. Fill system. Close bleed bolt when coolant starts to run out without bubbles. Tighten bleed bolt to 84 INCH lbs. (10 N.M). With radiator cap removed, start and run engine until normal operating temperature is reached. Top off coolant and install radiator cap.
SPONSORED LINKS
Sunday, February 1st, 2009 AT 9:03 AM
