1993 Acura Legend any problems
1993 ACURA LEGEND
5HLW
  • 7 POSTS
1993 Acura Legend Automatic
I have a 1993 legend nd when i give it gas it goes tht act lik it bck bck lik it not gettin the rite trottle respone. Wht could be cause tht. ?2 I heard lik a air noise from my brake booster nd the brake r no wrkin rite is the brake booster bad or need to b bleed
Apr 8, 2010 at 2:18 PM
KHLOW2008
  • 41,814 POSTS
Hi 5hlw,
The engine seems to be misfiring and you should get the spark plugs and related parts checked.
The brake booster is leaking vacumn and is not a bleeding problem. Either the booster is bad or you have a vacumn leak between the master cylinder and booster.
Apr 9, 2010 at 2:04 AM
