HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Acura
Legend
Engine Cooling
Leak
1991 Acura Legend
CTRAYLOR
MEMBER
1991 ACURA LEGEND
6 CYL
2WD
AUTOMATIC
250,000 MILES
Leaking water from front of engine
Thursday, August 5th, 2010 AT 2:00 PM
KHLOW2008
MECHANIC
Hi ctraylor,
There are many possible areas to leak from fron of engine and the most common would be the water pump. Get a pressure test done if you are not able to locate the source.
SPONSORED LINKS
Friday, August 13th, 2010 AT 1:26 PM
Please
login
or
register
to post a reply.
Related Leak Content
1995 Acura Legend Thermostat Where To Find It
Running Hot Then Cuts Off
Asked by
fayef
1995
ACURA LEGEND
VIDEO
Cooling System Pressure Test For Leaks
Instructional repair video
GUIDE
Coolant Leak Symptoms
When your car begins to leak coolant the first indicator is the engine will start run hot and possibly overheat. This will be noticed by the driver by observing the...
1992 Acura Legend Radiator Light Indicator
1992 Acura Legend 6 Cyl Front Wheel Drive Automatic I Have A 1992 Honda Lengend. My Worry Is That The Radiator Light Shows Up After...
Asked by
Osagie
1992
ACURA LEGEND
1995 Acura Legend I Pulled My Radiator Overflow And...
Engine Performance Problem 1995 Acura Legend I Am Losing Alot Of Power Most Of My Buddies Tell Me Blown Head Gasket But I Dont Just...
Asked by
drayko321
1995
ACURA LEGEND
Where Can I Find A Thermostat Valve?
Have Check With A Few Acura/honda Dealerships, They State Part Is No Longer Made And None In Stock. This Is Broken Part Is Keeping The Car...
Asked by
Patricia Lopez
1 ANSWER
1989
ACURA LEGEND
SPONSORED LINKS
Online car repair manuals
