1989 Acura Legend Air Conditioner stops cooling after 30 mi
TMT07
Air Conditioning problem
1989 Acura Legend 6 cyl Two Wheel Drive Automatic 250k miles
Hello, I have an '89 Acura Legend which has well over 200,000 miles on it. Basically the I use the car to do courier work, so naturally it's driven quite alot. I stay on top of all maintenance work that needs done in order to extend the life of the car as long as possible. In all honesty I have a good mechanic and he really takes good care of me (actually my car). He has charged the A/C, checked for leaks, and yet I still can only get it to cool for about thirty minutes before it stops cooling the car. The A\C system is charged, and upon inspection appears fine, but after driving for 30 minutes or so it slowly peters out. Has anyone else ever experienced such an issue before, or are familiar with what's causing it to slowly stop cooling after it's been on for a short while? I'd certainly appreciate some insight regarding this problem if anybody has a good idea what might be happening, as it's hot & humid now and it just makes these deliveries I do anything but comfortable! Thanks in advanced, & I do appreciate anyone taking time to read my question!
Jun 14, 2008 at 1:17 AM
KHLOW2008
  • 41,812 POSTS
Hi tmt07,
There are many possibilities but the info you have given is insufficient for any one to assist.
When the cooling stops, was the compressor still working?
Did you get the pressure reading of the low and high side?
Were the condenser and radiator fans working?
Jun 14, 2008 at 2:00 AM
