1990 Acura Legend
JUSTIN.LEHMAN
  • 1990 ACURA LEGEND
  • 6 CYL
  • FWD
  • MANUAL
  • 165,000 MILES
I recently had to change out a few pieces of my a/c system (pump, pressure hose, condenser fan) and all seems to be working well with no visable leaks. I charged up my system but my a/c will not get cold. Is there an place I should go back and check or something new I should have checked?
Monday, July 28th, 2008 AT 8:14 PM
KHLOW2008
  • 41,814 POSTS
Hi justin,
Please provide the high and low pressure readings.
Is compressor clutch engaging full time?
Sunday, August 3rd, 2008 AT 6:19 AM
JUSTIN.LEHMAN
I can hear the compressor coming on and off but will need to get back to you on the high and low pressure. I was not aware I needed to even check the high side.
Tuesday, August 5th, 2008 AT 7:56 AM
