1988 Acura Legend Oil leak
1988 ACURA LEGEND
200,000 MILES • 6 CYL • FWD • MANUAL
JLONG2002
What would cause a steady drip of oil only when started?Not the oil filter, oil pan gasket, or no valve or cam covers leaking.
Mar 20, 2008 at 10:19 PM
SERVICE WRITER
  • 9,123 POSTS
Anywhere there is oil pressure. Not sure if this has oil cooler lines, but that would be a common point on many. Oil pressure sending unit maybe. Main seal.
You need to get good lighting use mirrors if needed and start looking.
Mar 20, 2008 at 10:27 PM
