i have a 96 integra, has the stock ls/ non vtec bottom end but has a 98 gsr/ vtec head. it has drove ok for a while and then it started to knock the last 2 times when i first stated it up, it would only last for a second then it would be fine, well i was driving normal at about 50mph last night and i felt the motor lag a little and i look down at the gauges and the oil and battery light come on. as soon as i see that i shut it off and coast, when i come to a stop the oil is fine, i tried to start it up but it will try and turn over but not fire, what should i do??
Aug 13, 2007 at 9:28 AM
